18cc poulan
My Feedback: (16)
This engine, while it works great as originally intended, hasn't worked out as well for a converted model engine.
The ports are small and the displacement to weight ratio is not as good as some of the bigger engines. It's more of a 13-6 at 7,000 rpm motor.
The Homelites, Ryobi, McCulloch weed whacker work better.
Any more, the Poulan & Homelite small chain saws have been popular.
Enjoy,
Jim
Enjoy,
Jim
cut that baby up ,adapt .61 glo carb on it swap the plug for a glo ,look out power like .90 I,ve done up a 18cc,21cc,30cc,
there,s nothing out there you can convert,thet can beat the power to wieght ratio.
I agree with Rcpilet. Slap a glow plug in and try gas/glow fuel. If you do not like that try glow fuel with 5 percent oil in it. May some Nitro if you need more power. Just eperiment untill you get the results you want. Capt,n
