Which Engine Size???
Old 12-02-2009 | 03:32 PM
Default Which Engine Size???
Hello... This question is for all of you weedwacker converts out there... I am a new convert myself and I am building a Cessna Agwagon from scratch. It will have a ws of 84". I could probably use a 120-size glow, but I really want to put a gasser on it. Unfortunately, I don't know which engine to use. I have a Homelite 25cc lying on the shelf collecting dust. Are there any rules of thumb to go by when choosing engine / prop combos for aircraft size??? Thanks in advance for the info...
DF
Old 12-02-2009 | 10:41 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Which Engine Size???
The Homelite 25 will be fine
It will pull a 18 X 8 if you put a "28" size carb on it and open up the exhaust. About 7000 rpm
Otherwise you will have to run a 16 X 10 still about 7000 with the stock carb
Old 12-04-2009 | 01:34 AM
Ralphbf's Avatar
My Feedback: (27)
Keep your eyes open for the 30cc Homelite.
It's the same engine different bore lighter and more power.
Old 12-04-2009 | 12:03 PM
av8tor1977's Avatar
Just so you know, you can quickly tell if a Homelite 25/30 series engine is a 30 by looking in the exhaust port. The 25cc engine has a bridge in the exhaust port, and the 30cc does not.
The Homey 30's were getting hard to find, but the newer Ryobi weedeaters I found have Homelite 30cc engines in them. The 30's work quite well.
AV8TOR
Old 12-04-2009 | 07:13 PM
Guys, thank you all for the info. This is definitely what I needed to know. Once again, thanks...
DF
Old 12-16-2009 | 11:45 PM
buck1856's Avatar
My Feedback: (49)
Im about halfway through converting a stihl 25cc.Check out the stihl threads.I have a stihl 28cc thats putting out 7400-7600-rpms with an apc 17x8,and its a used engine.
Old 12-16-2009 | 11:58 PM
w8ye's Avatar
My Feedback: (16)
That's pretty good power for an engine that size
Old 12-18-2009 | 01:01 AM
buck1856's Avatar
My Feedback: (49)
Number 28 in carb throat,Ken Lambert muffler,ch ignition timed at 28 BTDC.No advance.
2 rings on piston,everythings stock.Prop came off my OS 160 before i sold it.
Tri mount on back,Rail mount on botom.I think it came off of a FS-46.[Stihl].
ID:	1336827   Click image for larger version
ID:	1336828   Click image for larger version
