source for short blocks for conversions
Old 01-20-2010 | 08:30 AM
Default source for short blocks for conversions
I am looking for a source for new short block echo engines, I have had some luck at my favorite small engine shop but these engines are generally used, cheap, but used.
Does anyone know where I can get these engines new in short block form (without having to buy 10,000 of them)
Old 01-20-2010 | 11:05 AM
av8tor1977's Avatar
Default RE: source for short blocks for conversions
You can buy them. Search the internet for small engine parts sales. When you find some sites, what you are looking for is called "repower" in the parts sections. But get ready, they are very expensive. Usually $200.00 plus for Echo engines, without carb, carb adapter, muffler, ignition, etc.
AV8TOR
Old 01-20-2010 | 11:35 AM
tim220225's Avatar
Expensive yes but you can luck into some. I bought 15 23.6cc short blocks for $15.00 each as I recall. Sold some to a few guys here. Only problem with them was they were LH thread so you needed to do a little extra machining. I have never had any luck finding bigger displacement engines for what it is worth.
Old 01-20-2010 | 02:24 PM
I have been looking for two 21cc echo engines for a twin senior telemaster I am going to build. I found a site that has the short blocks for $124, and on ebay I think they were 109. These engines were for the PB2100 blower, was there not a thread problem with the crank on this engine?
Ken
Old 01-20-2010 | 03:52 PM
tim220225's Avatar
Don't know which way the engine spins in the unit. Either way the threads are not an issue. I just cut the threads off and bored and tapped a hole in the crankshaft, used a stud to mount the prop from there.
Old 01-20-2010 | 09:47 PM
Just did that:
ECHO CS1080 shortblock, New from DLSMITH_23 on ebay $124
Farmers exchange wants about $210
Walbro WT-542, ECEDWARDS_TOOLS on ebay, $15
IF you don't have a lathe then go to,
Brillelli Customs for:
a prop hub $30
intake manifold $27
Get or make a muffler, ~$50?
Buy an ignition , ~$80
About $280
You now have a BME 50 clone!
$124 bucks for a little engine? I would not do that. Harbor Frieight Tools has Poulan chansaws for right at $100. They are very good for conversion. Use the engine and sell the rest on on EBAY? The weight will be simmilar, just throttle back. I got a thirty something CC echo saw at OSH for $30 a while back, no bar and refirbished, it was new.
Here is one on EBAY now:
http://cgi.ebay.com/Used-Poulan-Chai...item5ad669d0d6
Old 01-22-2010 | 11:43 AM
Farmers exchange has the 21 cc echo for $99, nice and clean don't have to tare anything apart, thank you for that info.
Old 01-22-2010 | 12:47 PM
j_t01's Avatar
I just came across a crate of new 25cc Husquvarna trimmer engines at work that can be had for cheap. PM me for details if anyone interested.
Jim
The pic shows an example of what's avail.
Old 01-22-2010 | 01:14 PM
what brand engine are they?
Old 01-22-2010 | 01:16 PM
j_t01's Avatar
They are Husquvarna. I have about 20 left in various stages of complete.
Jim
Old 01-25-2010 | 07:13 AM
j_t01's Avatar
Some of you have asked for better pics. Hope this helps.
Old 01-25-2010 | 09:06 AM
I am sorry I should have said what make is the engine
Old 02-01-2010 | 08:24 PM
delete this post
