A $5 LED stroboscope
Old 07-17-2010 | 03:47 PM
Gompy's Avatar
Default A $5 LED stroboscope
If we building CDI's and TCI's, we need also a good strobe to see wat we are doing.
http://www.electronics.gompy.net/strobe/
The designe it's mine, I only redesigne the pcb and use normal components.
Old 07-17-2010 | 10:14 PM
gkamysz's Avatar
My Feedback: (19)
Default RE: A $5 LED stroboscope
Is this sensitive enough to pick up the spark through a shielded spark lead like used in most model spark ignitions?
Old 07-18-2010 | 08:44 AM
Gompy's Avatar
ORIGINAL: gkamysz
yes, it pickup even the spark of a electric lighter.
Old 07-18-2010 | 10:00 AM
Hello, this scope is a good idea. Is a kit or at least the PCB available for purchase from you or someone? Thank you very much.
Sincerely,
Richard
Old 07-18-2010 | 11:45 AM
Gompy's Avatar
It will cost more then $5 if I make the pcb and send it to you from the Netherlands.
With this program http://www.baas.nl/layo1pcb/uk/downloads.htm and the files from my website you can make the pcb by yourself.
Other option, find somenone into the states who can / will make the pcb.
Old 08-19-2010 | 03:36 AM
made up one of your strobe units and it works fine...thanks
Old 08-19-2010 | 03:43 AM
By the way, how do you add a photo here..??
Old 08-19-2010 | 08:40 AM
Select "reply" at the top of the posting. Then, at the bottom of the reply message in a set of boxes starting with "File" are two choices for sending images. Select one and follow the prompts.
By the way, have you made a PC board, and will you sell them? Please advise.
Good luck.
Regards,
Richard
Old 08-20-2010 | 03:06 AM
OK...thanks for that. I will give it a try.
Yes, made my own pc board but do not get enough free time to make extras sorry.
Old 08-20-2010 | 03:18 AM
av8tor1977's Avatar
Will this work even if the spark plug wire has a wire braided shield??
AV8TOR
Old 08-20-2010 | 05:30 AM
Gompy's Avatar
Yes, maybe it's even to sensitive.
Changes R3 into 1k and R4 to 15M.
Don't use a coil but a simple crocodilclamp.
Old 02-19-2011 | 01:30 PM
gkamysz's Avatar
My Feedback: (19)
Rob, Is this circuit still up on the site somewhere?
Old 02-20-2011 | 12:21 PM
I can probably make some boards for the stroboscope. Whenever I make a board, I always print out more positives than I need for my projects. How many should I make and for who?
John
Old 02-20-2011 | 12:30 PM
gkamysz's Avatar
My Feedback: (19)
John, I'd take one.
Greg
Old 02-20-2011 | 01:18 PM
If anyone wants one, PM me with your address.
John
