Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Esky Helicopters
 Replacement servos for King2 >
Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Old 08-10-2007 | 08:58 AM
Default Replacement servos for King2
I want to replace all the stock servos on my King 2. Is there any particular ones that last longer or work better than the stock ones that don't cost a lot more? Thanks
Old 08-10-2007 | 09:17 AM
Default RE: Replacement servos for King2
I am going to do the same shortly and was told that the servos from the DX6 will work and fit the King V2. Hope that helps.
Old 08-10-2007 | 09:45 AM
DriveWRX's Avatar
I use 3 Hitec HS-55s for the swash and an E-Flite S60 for the tail on my HB King V2.
The HS-55s cost about $14 ea. and the S60 is about $17 at the LHS. You can find them cheaper, I'm sure, online (eBay ).
Lots of people use the Hitec HS-50 for the tail and are happy with it. It does cost more: about $22.
The 2 rear servos on the swash need their mounting holes elongated inwards to get a proper fit. Otherwise the HS-55s are a direct drop in.
Good Luck and Happy Flying!
-Vince
Old 08-11-2007 | 04:31 AM
I just got 3 hs55's with shipping from www.hobbyhorse.com for 37 bucks =)
Old 08-13-2007 | 08:51 AM
ORIGINAL: DriveWRX
-Vince
Question: Do the HS-55 servo connectors plug right into King 2 receiver ok, or do you have to make some mods?
Old 08-13-2007 | 08:56 AM
ezveedub's Avatar
They should plug in, HiTec uses S-Plug, Futaba has the J-Plug with tab on the side.
Old 08-13-2007 | 03:36 PM
DriveWRX's Avatar
Yes, what ezveedub said.
From my experience and what I was told at my LHS, the S-plug is more commonly used by manufacturers.
Old 08-14-2007 | 12:54 AM
yeah, they plug right in. They may rotate the reverse direction though, so you will have to do the servo reverse mod on one of the servo's and then swap the two rear channels and possibly reverse some servo channels, but it should be as simple as that.
I am currently working on a write up for how to upgrade to the hs 55's
someone in another thread also mentioned that they have two different versions of the hs 55's, one that turns cc and cw, so if that is the case, then you wouldn't have to do the servo reverse mod.
