ESKY LAMA 4 THREAD
#301
GA
Joey, with the new tail boom you could be tail heavy (center of gravity is off). Suspend the heli between two fingers by the fly bar so it hangs below your hand, if the boom doesn't hang level you need to move the battery forward to make it hang level. I'm not sure how to do this on the Lama. I haven't really dug into the mechanics of the Lama, my wife has a stock one that she flies and other than charging batteries for her I haven't really messed with it. It does sound like your CG is off with the new boom though. The swash plate could also need adjusting if it isn't level with the TX turned on, trims centered and battery plugged into the heli.
#302
UT
ORIGINAL: joeyhatch11
So I FINALLY got my Xtreme tail boom and support bars. But now I have a problem with the heli drifting backward really bad. To the point where my Tx is turned all the way up for fine adjust. What to do to correct this mess?
#303
NJ
Well I took the linkage off that gives the heli forward/backward flight and turned it out a few turns and now everything seems fine. I have a little shake in the tail boom that I can't get rid of but I doubt that's ever going to be perfect. It says to turn the gain down to help get rid of that shake but my gain it all the way down. hahaha. I gotta tell you though, the new tail with the supports looks pretty good even on the stock landing gear. I dont know if I'm going to upgrade that just yet. Maybe after I destroy the stock ones. LOL
Hows everyone been out there in heli-land?
#304
CT
ORIGINAL: GTX SlotCar
OK. I just went through this again.
The left trimmer pot is for the gyro gain. The right pot is the motor mixer. It seems to operate in a counter intuitive nature in that a CW adjustment will spin your heli CCW. So, the easy way to remember it is that if your heli IS spinning CCW, turn the trimmer CCW to correct it.
Turn the left trimmer (pot) all the way down (CCW). This basically shuts off the gyro.
Center your rudder trim.
Fly the Lama for a couple minutes to let the motors (and 4in1) warm up.
If the heli is spinning CCW, turn the right trimmer (Proportional) CCW.
If the heli is spinning CW, turn the Proportional trimmer CW.
Keep doing this until the Lama stops spinning on its own, or get it as close as possible.
Once this adjustment is as good as you can get it, increase (CW) the gyro gain on the Gain trimmer. Small steps are best. This locks the gyro. but too much lock will cause the tail to shimmy back and forth as it "hunts" for center. It will also probably slow down the speed of the tail so you won't be able to spin it as fast.
#305
GA
Correy, check page 1 post 9 for complete adjustment procedures for your V4. I followed these last weekend for my wife's and it flies beautiful.
#306
NJ
Want to hear something stupid? I took my heli to work yesterday to fly around on break but I never got the chance to. So it stayed in the car, inside the box the whole day. I guess because it got so hot in there that the blades warpped on me and now it flies like crap. Both sets of blades are not tracking right and the heli has a nasty wobble in the air. My luck right? So I went online last night and bought ANOTHER set or Xtreme blades along with a new gear and shaft set (B) and a new fly bar because that managed to get all bent to hell. Just when I thought all was good and I was done buying for this heli and I was getting ready to get a new FP this happens.
#307
NJ
So I had my parts overnighted from HeliDirect. I gotta say they are kick ass over there. Turns out my blades were way out of wack and my fly bar was pretty beat up. After installing the new blades and fly bar all was perfect again. Well I hope everyone enjoys there 4th of July. 3 day weekend means lots of flying for me. Hope the weather holds up.
#308
Try dropping the warped blades into boiling water for a few seconds and seeing if it straightens them out. I'm curious if that is what the "boil the blades" trick fixes.
#309
NJ
But I think even after you boil the blades you would have to wrap the boiled one aruond a new one to get the shape back. If not, wouldnt it be flat? Either case, I put the new blades on and she's better than ever. I flew 5 packs through it yesterday. I think on Friday I'm going to order another 2 batteries from Hong Kong.
#310
CT
ORIGINAL: Bones27
Correy, I recommend buying from here: http://www.ushobbysupply.com/product...1e49e3fec531bc Note on his home page that he is out of town on business an is not shipping until Saturday I beleive but check to make sure. You will not find better customer service anywhere.
Thanks for recommending US Hobby Supply. I received my order today and I’m very satisfied with their service. I’ll definitely be doing more business there
#311
http://www.youtube.com/watch?v=RmNv8OlG6GQ
#312
Hi all, I'm a complete newbie to this and just received my lama today, but it doesn't hover without me pressing left on the throttle to try to trim it, this is after using the trim on the transmitter as well. I've been reading about the 4 in 1 should I reset it and start from scratch trimming it out?
#313
NJ
I had the same problem when I got mine and I asked the same question. To fix this problem reset all the trims on the Transmitter to normal. Then turn your "GAIN" all the way to the left and then turn it to the right about 1/4 turn. For the Proportion gain turn that all the way to the left and then turn it out about 1/2 way. Start from there and if it still moves alittle to the left just make minor adjustments by turning the proportion gain the the left. If it moves to the right then adjust the Proportion gain to the right.
Which ever way the heli's tail is moving, is the same way you want to adjust the proportion gain on the heli. But remember to make only minor adjustments at a time. Also, once you make the adjustments remember to unplug the battery and plug it back in so it will re-calabrate. The GAIN controll on the 4-In-1 is to help with the tail shaking and the proportion gain helps with making the tail not move to the left or right. I hope this helps. It did for me and now my heli is rock solid. Happy flying. Joe
#314
NJ
Well one of my motors finally took a crap on me today. Sucks too because I was having so much fun. I had it out front of the house and I was going nuts with it. One pack went dead so I ran in for another when I came back out and powered it up she fly for about 3 seconds then landed. All she does now is spin around. The front motor gets pretty hot while the back on is nice and cool. So I'm going to order new ones tomorrow and hope to get them Monday. How's everyone else doing with there Lama's?
#315
CT
#316
No matter how far I turn each screw it doesn't make a difference, they both seem to have no effect, both rotors start at the same time, but as more throttle is applied it just leans to the right and hits the floor? any ideas?
#317
ORIGINAL: sharob
#318
#319
Done that, but to no avail, by using the throttle in only the up motion should it take off or do you need to compensate on the joystick whilst increasing the throttle?
#321
Ok, charged up the battery, went to connect it, the front motor burnt out! bugga less than 24 hrs old! anyways I have noticed that the swash plate isn't level (it should be level shouldn't it?)once the tx and rx have been turned on, so I will try adjusting the servo when I get a new motor. Are these helis really this hard to get in the air?
#322
NJ
I never had any issues like that with mine. She flew fine once I found out how to make the proper adjustments. And the only reason why I'm getting new motors now is because I've put about 50-60 packs through them and the one rear motor finally gave out. But other than that she's a keeper. I have the Xtreme blades, tail boom and extended shaft. Since those upgrades everything has been great.
#323
It's not the motor, it's the 4 in 1, I connected the "burn out" motor to the other side of the 4 in 1, it worked for a couple of seconds and smoke came out of the 4 in 1, now that side doesn't work, I'm looking for a replacement 4 in1!
#324
The suggestion given to you by downunderdog is the right one. If it leans to either side(leaning is called yaw) you should correct this problem by disconnecting and shortening or lengthening(this depends on what direction the leaning occurs) the servo linkage rods.Centre all trims and connect a battery pack,work your way from there until the swashplate is level adjusting the servo linkage rods if the tx trims dont totally correct the yaw. Dont worry about the heli being difficult to fly,with the right trim and some patience you will soon become a pilot. Took me a week of blade breaking to feel i could fly (almost) anywhere.
#325
Mine is also flying great but i have had to remove the xtreme extended shaft. Was having tbe with it. Has this happened to you with the new shaft? Recently changed the stock (and very short cos they were cut) servo arms and moved the rod to the second hole(new arm has five!).Have had a significant improvement of foward flight.Any you guys tried doing this??? Will move to the other holes soon and let you know if its recommendable.
