Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Everything Diesel
Unknown Diesel engine - can you identify? >
Everything Diesel Discuss R/C Diesel engines here.
Old 05-16-2015 | 02:47 AM
1QwkSport2.5r's Avatar
Default Unknown Diesel engine - can you identify?
I know someone that has this engine. It doesn't appear to be a traditional diesel, but it has a contra piston it looks like. Just trying to help him identify the make/model. It's very small - I US quarter dollar for scale.
ID:	2096279   Click image for larger version
ID:	2096280   Click image for larger version
Old 05-16-2015 | 04:32 AM
It has some resemblance to a Ukrainian RIRE Fora 09 Diesel that I own. I'm guessing that it's rear exhaust and has a drum valve, it's a bit hard to make out detail in the pics..
I'll guess it it's a Fora 020-049 variant even though I've never even seen a pic of one. .There was a glow Fora 020 with r/c throttle and front induction though.
Old 05-16-2015 | 07:06 AM
Here's another photo.
Old 05-22-2015 | 11:46 AM
I don't know the engine, but I'm surprised no one has mentioned that it is TINY!!
For those outside the USA, a dime - USA$0.10 - is about 48mm in diameter. It does look about the size of a Cox PeeWee 0.02 (reed valve) glow engine.
I'll be one of those interested to learn just what it is.
Old 05-22-2015 | 11:53 AM
It was mentioned on another forum as possibly being a FIT .020 diesel I believe. I do not own the engine, I was just trying to spread the word in hopes of identifying it. It is a cute little thing.
Old 05-22-2015 | 01:10 PM
earlwb's Avatar
With something that small, you would likely need to run 90% ether and 10% oil, maybe even more ether. Maybe a pinch of cetane booster thrown in too.
Old 05-22-2015 | 05:02 PM
coriolan's Avatar
Actually a US dime is 18mm in diameter(a bit less than 3/4"), which makes it a very small engine indeed!
Old 05-23-2015 | 05:07 PM
The FIT range of glow and diesel engines were produced in the Netherlands a few decades ago IIRC. Mostly performance 2.5cc glow and diesel engines for international class FAI competation I believe.
Sounds reasonable that they could have produced an 020 Diesel.
However I've since discovered a FITS range of small diesels made in the Czech Republic on the Ron Chernich MAN site..
Ron also has a pic of a FITS glow twin.
Old 05-24-2015 | 12:13 AM
I guess those Fits are the ones with the square pistons.
Old 05-24-2015 | 04:14 PM
No, I think that they were the Doesn't Fit range of diesels.
