Norvel
![](/forum/images/badges/trading_plus_member.png)
TN
That would be true normally but the oxide finish they call rev-lite turned out to be a very poor conductor of heat, that is why the Fin's are so much larger. Here is a good question: What manufacturer would add to his cost by using more metal to make a cylinder intentionally? Answer only someone that wanted the wear characteristics and did't care about weight or cost. Remember there Russians not Americans they have a different way of looking at business its a new thing for them.
That's a good point. Revlite is actually hard anodized, or aluminum oxide of a sort. Perhaps something of an insulator. Will do some research.
The early Revlites had normally sized fins though. I had thought that the large fins were something of a cosmetic, marketing tool. Many complained about how ugly the Norvels looked and it appeared that the larger fins were the answer to that complaint.
Having said that, and thinking that the Revlites ran too cool, I've turned down the fins substantially on two of the .074s and have had no problems whatsoever with overheating. I did this primarily because I fly in the winter and was concerned about overcooling. The cut down fins haven't been a problem even in the summer with very hot, and humid days. Perhaps I'll try the head conversion on a cut down .061 and see what happens.
