EvoJet Direct Support When you have questions and need help from the source, discuss the EvoJet here.
oil types
Old 03-12-2010 | 07:23 AM
Default oil types
hi all
just got my hands on a used g booster 80.
in the instructions it says turbine oil. wot other oils will be suitable?
could i use mobil dte light with this turbine?
thanks for any advice
cheers
snatch
Old 03-12-2010 | 05:01 PM
InboundLZ's Avatar
My Feedback: (10)
Default RE: oil types
I am not sure on the exact specs for a Booster 80 but the evoJet Booster 90 calls out MIL spec MIL-L-23699. The booster 90 manual calls out Areoshell 500, but any MIL-L-23699 spec oil will work fine. I run BP 2389, BP 2380, and Mobil Jet 2. All with no issues.
I know Chad runs a Red line synthetic oil, he can give you specifics on that oil.
Old 03-12-2010 | 05:35 PM
Snatch,
When in doubt, go with Dave's advice and run MIL-L-23699 spec oil. I am testing the Redline 2 stroke Racing oil as we speak so the factory can compare the wear patterns to that of aeroshell 500. For now, stick with the commonly accepted turbine oils.
Chad
Old 03-12-2010 | 07:26 PM
thanks for that guys.
got a few tins of bp turbo oil to go at for now.
thanks again,
snatch
