STEERING AND THROTTLE are NOT WORKING
PLEASE HELP!!!
I just bought a brand new 1/10 off road buggy from herehttp://www.nitrorcx.com/51c812-firered-24ghz.htmland the steering and throttle are not working
does any one have anysuggestions?
RE: STEERING AND THROTTLE are NOT WORKING
Yes the receiver has battery power, and the receiver is picking up signal from the transmitter because the LED light goes solid once they are both turned on. what sort of connections am i looking at that could be the problem?
Yea they are connected and i tested and volts are getting through to the servo but nothing is happening so yea i think i might need to get new servos which sucks because i haven't even drove the car yet :
KY
yea that is common on some trucks, factory servos arent always the best. just go grab some standard futaba servos. they work just fine and dont cost alot.
KY
Its alright, Are you breaking it in? If so then yes there will be quite a bit, after break in there will still be some coming out of the exhaust, if you have a good tune it some will come out but not a whole lot.
yea thats good then because i have finished breaking in now and there is only a bit coming out, if there was to much coming out what would i adjust low speed or high speed needle valve?
