Exceed RC Electric DriftStar Carbon Blue 1/10 2.4Ghz RTR RC Drift Car
https://www.nitrorcx.com/51c806-carbonblue-24ghz.html
The EXCEED RC Electric Drift Star model represents a new generation of 1/10 scale on road drift car. This RTR Drift Star car is electric powered and perfect for indoor or outdoor drifting. Based on our popular and durable on road electric powered car, this drift version adds specially designed sold compound drift tires pre-mounted high performance wheels. This RTR Drift Star car is 4WD for for consistent drift action on a wide variety of surfaces, easy to drive, and has all of the features you need to adjust for a perfect drift set-up: camber, toe-in, body level, etc.
Specifications
Length:360mm
Width:200mm
Height:112mm
Wheelbase:260mm
Track:195mm(F/R)
Gear Ratio:6.52:1
Ground Clearance:4.5mm
Weight:Approx.1350g
Wheel:65mm(Diameter),26mm(Width)
Motor:RC540
Battery:7.2V, 1800mAH (Charger Included)
Features
Four wheel drive system
Excellent front/rear camber and toe-in setup
Powerful RC 540 motor
Anodized aluminum centre long drive shaft
High performance front/rear differentials
Stable suspension arms and solid front/rear shock tower
Precise steering fitting delivers quick response.
High precision SP03018 electric speed control ESC
Complete ball bearings for a smooth and an efficient drive.
High performance anti-skid drift tires, chromes plated spoke rims and pre-mound drift wheels
7.2V 1800maH Ni-MH battery power (Charger Included)
Extra large front bumper foam provides protection against sudden impacts.
Specifications
Length:360mm
Width:200mm
Height:112mm
Wheelbase:260mm
Track:195mm(F/R)
Gear Ratio:6.52:1
Weight:Approx.1350g
Motor:RC540
Features
