MadGear BSD Racing SCT2 1/10 2WD Short Course Truck RTR (Red) RC Remote Control Radio
https://www.nitrorcx.com/72c109-2wd-...d-rtr-24g.html
The SCT2 truck is a rear wheel drive 1/10th scale off-road 2 wheel drive electric vehicle. It comes equipped with fully adjustable suspension and long travel oil filled shocks providing the utmost performance in terrain dampening. The suspension package provides an ample amount of ground clearance allowing the driver to coast over the most technical of obstacles with ease. The power system is derived from a hi-torque 540 brushed motor and supported by a brushed waterproofed proportional electronic speed controller. The torque and power is transferred to the adjustable rear differential delivering power to the rear two wheels. Traction is obtained by the aggressive tread patterned off road rear tires. The entire power system is produced by a 1800mAh Ni-MH battery with charger included. Handling all the cornering and steering inputs is a 9kg rated waterproof standard sized servo. All this awesomeness is controlled by a frequency hopping 2.4ghz radio system which will ensure positive feedback and interference free operation for plenty of fun.
Features:
• DuPont lightweight chassis plate and roll cage
• First pressing DuPont plastic towers and wishbones
• Low centre of gravity for better handling
• Fully adjustable steering and suspension geometry
• Hi-torque brushed motor and sealed gearbox
• Adjustable Ball Differential
• Heavy duty drive shafts
• Long travel oil filled shocks
• Highwall bead lock style wheels
Specifications:
Scale: 1/10
Drive: Rear Wheel Drive
Battery: 7.2V 1800mAh NI-MH battery
Motor: RC 540 brushed motor
ESC: 1/10 brushed ESC
Servo: 9kg Standard Servo
Radio: 2CH 2.4Ghz radio system
Charger: USA Charger
Wheelbase: 290mm (11.4")
Ground Clearance: 20mm (.79")
Size: L: 430mm * 315mm * 150mm (16.9 x 12.4 x 5.9in)
Required to Run:
8 AA Batteries for Transmitter.
Features:
Specifications:
Scale: 1/10
Required to Run:
