Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
DIAMOND DUST RC LIVES!!!!!
Old 01-26-2009, 05:41 PM
  #126
skylab
Default RE: DIAMOND DUST RC LIVES!!!!!
Hello All, I Just wanted to update the links to the Assembly Manuals for both the Stock Diamond Dust and the CW version as well.
Gerry
DDust Team
Stock Diamond Dust:
http://www.diamonddustrc.com/Diamond...26-2009-01.pdf
Diamond Dust CW:
Old 01-30-2009, 03:46 PM
  #127
69 roadrunner
Hey guys lost my roll offsolartex tape is it a big deal to cover without it. The other thing has anyone sheeted there plane then glassed it what are thr pros and cones thanks steve
Old 01-30-2009, 03:58 PM
  #128
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
I think you should definitely get ahold of Diamond Dust RC and get a replacement. The coverite mod is pretty critical.
As far as sheeting the whole thing and glassing, I think that would add a lot of unnecessary weight.
Old 01-30-2009, 09:28 PM
  #129
combatpigg
combatpigg's Avatar
All I've ever used is either Monokote or Towerkote, no issues.
Old 01-31-2009, 07:02 AM
  #130
freakingfast
ORIGINAL: 69 roadrunner
I agree with Goinstraightup on both counts.
I have used .003" X 1" Fiberglass Woven Tape in place of the Solartex tape with good results.
Old 01-31-2009, 01:25 PM
  #131
69 roadrunner
freakinfast where did ou find the fiberglass tape craft store or hobbie shop thanks steve
Old 01-31-2009, 02:08 PM
  #132
freakingfast
At my LHS, but this is what they sold me:
http://www.cstsales.com/glass_tape.html
Old 01-31-2009, 02:42 PM
  #133
freakingfast
The down side to the glass is you should pre stretch a length with about 5 pounds for a few hours before you apply it as it won’t shrink and get taut as the solartex does.
Unlike the Solartex you put it on before the Stix-it and pull it taut but don't warp the wing. You can use medium CA to tack the start and stop ends but keep it down and flat. Check the wings for warp again and lock it down on the cap strips and leading edges by wetting through finishing epoxy. CA at stress points can make the glass more brittle so it could crack and tear.
Whether or not you use glass or Solartex remember to coat the frame AND the tape with Stix-it before the Ultracote is applied.
Solartex is hard to beat, Jeff Gilbert did his homework.
Old 01-31-2009, 11:50 PM
  #134
69 roadrunner
where can I get the solartex thanks steve
Old 02-01-2009, 09:06 AM
  #135
ChuckL
Tower has it.
Old 02-01-2009, 10:57 AM
  #136
evan-RCU
evan-RCU's Avatar
Slow to respond I know but I have not put the solartex in any of my DDs with no issues.... I use Monokote to cover my planes...
Old 02-01-2009, 02:58 PM
  #137
freakingfast
This is the stuff, however you will need to cut it into tape width like DD does.
It may be cheaper to see if they will sell you a roll.
http://www3.towerhobbies.com/cgi-bin...&I=LXB185&P=ML
Old 02-02-2009, 12:39 PM
  #138
skylab
Hi Guys,
Just PM me and I can get a roll out to you for $3.00 Plus Shipping.
Gerry
DDust Team
Old 02-26-2009, 08:43 AM
  #139
Planeclaims
Add another Dust to the fold! Spektrum 2.4 & AR7000 for guidance. TT 36 Pro w/stock muffler turning a 9.5 X 6 Bolly prop. I have a mousse can pipe assembly but header pipe needs slight bend to relieve stress on can's saddle mount. 2 - JR 4735 elevon servos, Hi-tec HS85MG throttle servo. Ultracote covered. Did not use the fiberglass tape. Weight - 2.5 lbs. without fuel. Thanks guys, for kitting these fabulous aircraft again. Maiden flight 2/28/09 w/stock muffler. CG middle of recommended range on plans. Bottom of elevons flat with bottom of aircraft body. Self-hand launched @ half power. Model required more up elevon trim than expected, perhaps due to beveled elevon modification? Still a hoot to fly.
Steve
Old 03-06-2009, 12:51 AM
  #140
69 roadrunner
Hey guys here is a pic of my ney DD The RoadRunner
Old 03-06-2009, 04:07 AM
  #141
freakingfast
Two nice looking Dusts guys!
What type of Jett motor is that?
Old 03-06-2009, 08:46 AM
  #142
Goinstraightup
My Feedback: (26)
Cool bird on your DD roadrunner.
Old 03-06-2009, 09:45 AM
  #143
69 roadrunner
Thanks guys its at jett50 fire just got havent run motor yet. Just need to finsh linkage and get good weather.RoadRunner
Old 03-06-2009, 10:43 AM
  #144
Planeclaims
69 roadrunner,
Can't tell by your photo if you reinforced each elevon with CA hinge material (for mounting the control horns) per building instructions and plans, before covering. If not, it's highly recommended.
Old 03-06-2009, 12:00 PM
  #145
combatpigg
combatpigg's Avatar
I pin poke the entire area and beyond, where the control horns go, then saturate the wood with CA.
Old 03-07-2009, 12:46 AM
  #146
freakingfast
ORIGINAL: combatpigg
That'll work just fine in a pinch.
Old 03-08-2009, 10:31 AM
  #147
skylab
ORIGINAL: Planeclaims
Steve
Glad to see you guys enjoying them for this season. We still recommend to everyone to not omit the Solartex strips on the airframe.
It really plays an important role in "compartmentalizing" of the wings and covering which results in a much more sturdy airframe and
also allows more surface area for the covering to adhere to. Other than that you guys are building nice birds!!
PM me with your pictures and setup details. We are assembling a users section on the Diamond Dust RC site to share with others.
Keep up the good work!
Gerry King
DDust Team
Old 03-17-2009, 10:37 PM
  #148
KC10Chief
HA! I had the exact same setup on my old DD. It was scary fast. Dub even has my plane featured in his Hall of Fame photos. It's a red, white and blue one and my name is Matt Fulks. Anyways, that motor is wicked! It is extremely loud as well. Like, damage your hearing kind of loud. Bring a box of ear plugs with you so you can give them to people who are helping you launch that thing! Oh, and make sure you wrap your covering AROUND the leading edge. I learned that lesson the hard way when the covering instantly removed itself off the top of my DD. I was still able to land it. The plane got smashed when I moved about 5 years ago and I sold the motor. Wish I hadn't now. I'd get another DD.
Old 03-23-2009, 09:30 PM
  #149
Blade-breaker
I just ordered a DD C.W. today. Looking forward to the build. Looks like a breeze to put together. I am planning on using a OS 46FX that I have on hand to start with, hopefully it will move out good. Wondering about the servos required for the Elevons. Would some Futaba digitals with 90oz torque do the job (S3050)?
After I get some time on it I would really like to put one of those rear exhaust Jett engines on it. Looks wicked!
Thanks for all the tips!!
Ryan
Old 03-24-2009, 01:28 AM
  #150
apichart
Who Have Aplan Diamondust Plase ... Send tome ... Plase mail [email protected], and puipui@[email protected] , and [email protected]
thank so mush From Thailand
