OS 91VRDF exhaust
ON, CANADA
OS 91VRDF exhaust
Has anyone ever used a ducted fan pipe set-up for prop use, or is it better to go with the typical header/pipe set-up for this. I know you would have to mount the pipe more securely so its not flopping around.
My Feedback: (8)
RE: OS 91VRDF exhaust
I have a friend with one in his Yellow F-4E (Dynamax fan )
He runs Wildcat DF fuel which is 5% nitro and 23% oil. Not sure of the exact ratio of synth to castor but I believe it's at least 1/3 castor.
We used to have a LOT of DF activity over here at Griffiss (formerly AFB ) until they closed it down...the most I've ever heard of anyone using was 10% nitro in the O.S.
That was for longevity sake...but if you're willing to push it I'm sure you could bump it up some with the appropriate shimming, etc. etc.
ON, CANADA
ORIGINAL: RocketRob
Not this discussion
50-50 castor blend and add another ounce or 2 of castor to a gallon
start 10% nitro and see how your plugs hold out
The extra castor will not hurt you
walk then run? Eh?
Or do what CP or MJD would do
Not this discussion
walk then run? Eh?
I usually use OMEGA 15% and top up the jug w/ synth klotz oil for my engines, but this engine is obviously a little different, would the 10% omega be alright topped up with castor? [sm=72_72.gif]
GA
I still run glow ducted fan planes, both the .40 and the OS .90 FYI the Old K&B 45 is a great prop engine. Anyway fuel wise I use omega 10% then add 3oz of turbine oil to the gallon. The turbine oil will not break down at the temps glow engines run. I like the BP 2380 its what we use in our gulfstream biz jets. I have never lost an engine the fuel set up also works great is YS 45's
