Repaint of FMS 1`500mm P-47 to a 56th FG paint scheme
Hi All: haven't been here for a long time. I recently bought a FMS 1500mm P-47D razorback that I totally repainted to an authentic livery flown by a Lt. Albert Knafelz of the 56th FG out of England in WWII. It was a fun little project, a lot going on with all the colors it had, including full invasion stripes. Flies great, looks great in the air.
higher elevation view of aircraft
Underneath of aircraft. Note that one star and bar is much larger than the other. Many of these airplanes added a larger 55" star and bar on the lower left wing, followed later by one on the other lower wing.
Detail of a 500# bomb with front and rear fuzes and arming wires, which probably aren't really visible in this picture
Another shot of one of the 500# bombs
Closeup of nose art detail. Also the bazooka rocket pods are mounted in this picture. They were used for a short time on ground targets in the summer of 1944 by the 56th FG.
Shot taken from front left.
Some of the detail nomenclature from Callie
Actual aircraft taken in 1944. The plane was heavily battle damaged and crash landed back at base in England. The pilot survived but the plane was a write off and scrapped.
Lt. Albert Knafelz, pilot of the I Wanted Wings aircraft. He finished his combat tour and returned home safely to live a long life in the USA
Side view of aircraft with Heart Mountain near Cody, WY in the background.
frontal view of aircraft with invasion stripes and flaps down
shortround91 (09-23-2023)
Travail très impressionnant, j’ai choisi le schéma ''Miss Behave'' pour le mien. Et j’ai masqué la mousse sur les trous du moteur avec simplement une image web des cylindres du moteur et j’ai mis de la peinture sur les faux cylindres. L’impression finale n’est pas si mauvaise. J’ai également ouvert le cockpit et ajouté un ''Warbird pilot'' USA, changé pour une helice du Corsair de 1,7 m, et enfin, rebuiter le tableau de bord... SOme nomanclature à ajouter et ce sera ok.elice
Merci Callie Graphics pour les décalcomanies..!
Beautiful job the attention to detail is amazing, I’m just getting back into RC and am really enjoying the affordability of foam planes so my question is what type of paint are you using. Rattle can enamel etc just asking I’m looking at my second plane the T28 E-flight that I’m thinking of repainting after some flights that I actually feel good flying without worrying about crashing the whole time
