Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
GREAT PLANES SLINGER
Old 05-16-2012 | 03:18 PM
Default GREAT PLANES SLINGER
I HAVE THE GREAT PLANES SLINGER AND PUT AN E-FLITE SIX SERIES 2700KV BRUSHLESS MOTOR RUNNING A SPEED 400 HUNDRED PROP IN IT AND THE PROBLEM IM HAVING IS IN FLIGHT THE MOTOR WILL TURN OR TWIST IN THE MOUNT OR SADDLE IF YOU WILL . NOW I HAVE EPOXYED THE MOTOR IN And zipp tied it but it still does the samething SO ANY SUGGESTIONS ON HOW TO STOP THIS WOULD BE MUCH APPRECIATED. ALSO SHOULD I CHANGE THE PROP TO A SPEED 400 PUSHER PROP AS WELL??????????????????????????????
Old 11-18-2012 | 09:05 PM
Fred L's Avatar
Default RE: GREAT PLANES SLINGER
i used a piece of broom handle about three inches long with a square 2"x2" piece of 1/4" ply epoxied to the end of it, makes a great base for attaching any brushless outrunner motor to it. it is only zip tied down and have never lost position of a motor with it. I just installed a 3800kv outrunner motor and a 3cell lipo on it, test flight tomarrow .
