Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
Search problems
Old 11-03-2003 | 12:59 AM
My Feedback: (8)
Default Search problems
Searching does not work most of the time. For example: I'm trying to find info for an OS 1.60 so I try OS 1.60, OS, 1.60, "OS 1.60", and "1.60 OS"..... only when click on advanced search do these work... Also when I search for RCS I get no results. I know for a fact that RCS is in the forum in hundreds of replies.
Old 11-03-2003 | 02:11 PM
Banned
Default RE: Search problems
I just tried RCS on the advanced search and it works fine.
http://www.rcuniverse.com/forum/sear...mitbutton=+OK+
Also you must play with the drop downs if using the bottom right search as the results will vary depending on your settings. That bottom right search box looks ONLY through the forum that it is in and not all forums.
I searched for OS 1.60 (no quotes) and specified at the bottom to use "exact phrase" and it found pages of results.
