looking to get into FPV
Sorry to bother you, I need help. I am trying to flay my esay star with a new 2.4 ghz, 100 mw system with ce-osd cyclope, I hava a FM 72.550 (37) futaba rc, however. when I try to fly my easystar with them, the servos start to move unexpectebly, as crazy, while doing the range test with the FM antenna down with less than 7 steps away from the plane, and with the antenna fully extended the distance from the plane is less than 30 feet and all servos move all around.</p>
If you can help me to understand why this happen and which RC system is best for this type of 2.4ghz fpv.</p>
I read that if I use my 2.4 ghz Radio with this 2.4 ghz 1000 mw system I will reduce th range of my radio drastically.</p>
any advice pls.</p>
