TX 9ZHP - THR left to right
![](/forum/images/badges/trading_plus_member.png)
To change the trims press P and go into your Model Menu. Once there make sure the top line is highlighted and press K for the FNC (function) menu.
Here you will see that you can select which sticks, switches, and trim you want to control each item.
At the bottom of the page, press the letter that corresponds to your throttle channel. Once this is highlighted you can see on the far right hand side of your screen the options for that stick. Press Q for TRM (trim). The display at the bottom of the screen will change and give you 4 options of trims to be assigned to your throttle. Just press the corresponding letter of the trim that you want to control your throttle trim.
Now just press N to exit and you should be set up the way you like.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
