Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Faast: 2 planes, 2 Rx, 1 Tx, same problem
Old 08-29-2011 | 06:54 PM
Default Faast: 2 planes, 2 Rx, 1 Tx, same problem
(posting this for a computer illiterate friend)
The transmitter is a 6ex, each plane has it's own R617FS receiver and set of 3004 Futaba servos. On plane "1", the throttle servo started acting up, and wont idle down like it used to. The linkage is not binding and nothing has changed since plane was flown last. We pulled the plane's hatch and watched the servo arm "jiggle" back & forth as the throttle stick was advanced. With the transmitter throttle stick fully closed, the engine is revving at half throttle. Adjusting transmitter throttle trim up & down behaved as expected but not enough to fix the idle speed. We rotated the servo arm one gear and that got the idle speed more normal, However with the the throttle stick fully CLOSED, putting a tiny bit of BACK pressure on it (against the stop) makes the servo rev the engine HIGHER. Release the back pressure and servo arm closes the throttle slightly. Advance the stick and the servo arm jiggles back and forth as it travels to full open. All other channels work perfectly.
On plane "2", after flying normally all summer, the elevator servo developed a mind of its own, while all other channels still work perfectly. Touching the transmitter elevator stick makes the elevator servo jiggle wildly for a few seconds until it settles down and remains in position.
If the transmitter went bad, why does it affect the throttle on one plane and the elevator on another?
If the transmitter is ok, that means 2 different receivers or 2 different servos went bad at the same time?
Any ideas?
thanks,
Bruce
Old 08-30-2011 | 06:22 AM
Default RE: Faast: 2 planes, 2 Rx, 1 Tx, same problem
From what you are describing, it sounds like the pots may be bad in the transmitter. If your friend has had it a while, this could definitely be the case and bad pots will show up a lot as servo jitter.
I would recommend he send this in to have the pots checked out.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 08-30-2011 | 07:01 AM
Try some basic diagnostics to see where the problem is:-
Swap the receivers to see if the problem is associated with the receiver.
...and/or...
Swap a "working" servo with a "jiggling" servo to see if the problem is associated with the servo.
Best Regards,
=Adrian=
Old 09-01-2011 | 09:41 AM
Thanks for the info, i'll pass it along. I'm guessing it's only 2 years old, but since we can only fly on a handfull of weekeds during the summer with decent weather, neither the planes nor the transmitter have much "stick time" on them.
