Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
18MZ Warning Set
Old 03-15-2012 | 09:34 AM
Don Perry's Avatar
My Feedback: (51)
Default 18MZ Warning Set
Is there a way to set a warning on power up for the 18MZ for a switch like it does for throttle position.
I would like it to warn me if my gear switch is not in the down position on power up.
I have found the warning menu but it did not look like you could change anything.
Don
Old 03-15-2012 | 09:45 AM
exeter_acres's Avatar
Default RE: 18MZ Warning Set
the radio warns you if it is in any non-standard condition when you turn it on.....
so maybe set the gear up in a condition and it should work
Curtis
Old 03-30-2012 | 07:22 AM
Bax
The 18MZ doesn't have a way to have a warning that a particular control is incorrectly-set when you power up. It allows you to have a sound when you toggle the switch, so you can have a "Gear Down" message sound off when you move the gear switch to extend the gear, and a "Gear Up" message when you retract the gear, but not a warning upon power-up. You can only customize the particular sound you hear when you turn the power on, but it will sound no matter how any control is positioned.
If you set conditions so that the gear channel works only in condition 1, then you'll get a general warning that the switches aren't set correctly.
Old 03-30-2012 | 07:31 AM
Don Perry's Avatar
My Feedback: (51)
Bad, thanks for the reply. I'll try the condition setup as suggested.
Old 04-09-2012 | 11:51 PM
Hello
1. I will be glad to know if there is in 18MZ sound warning on low reception or loss of range for transmitter receiver?
2. is ther a seting for alert on the GPS speed sensor- high speed and low speed?
this report can be most helpful in F3A flying training
3. is ther a Out of box, in three-dimensional, warning buy GPS coordinates defineding? (perhaps I exaggerate a little bit with my expectation?)
this report can be most helpful in F3A flying training to
Thanks in advance
Chester
Old 04-10-2012 | 06:01 AM
Bax
Our reply in BOLD, below:
ORIGINAL: s-chester
Hello
You can set a low-battery warning. We don't know about signal reception.
We'll have to see what warnings are available when the GPS module comes out.
3. is ther a Out of box, in three-dimensional, warning buy GPS coordinates defineding? (perhaps I exaggerate a little bit with my expectation?) this report can be most helpful in F3A flying training to
Please see answer to #2, above.
Thanks in advance
Chester
Old 11-28-2012 | 07:06 PM
My Feedback: (10)
Does anyone know if the warning function for gear switch, etc will be in the next Futabe software update?
Old 12-16-2012 | 10:03 PM
Banned
i like OBD2
