R2006GS receiver
R2006GS receiver
The directions say to "press and hold the Easy Link button located on the receiver for two seconds and release it" I don't have a button on the receiver unless it is a hole labeled SW which seems to have a touch plate at the bottom of the hole. Is that my Easy Link button?
How to connect R2006Gs with multiple Servos
Hello Sir, I'm having following setup:
I connected the receiver with 7.4V voltage source through an ESC. The ESC gave a steady output of 5V. I used a single above mentioned servo which worked fine. As soon as I connected the other servo the receiver will loose connection to the transmitter and both my servos won't work.
- R2006GS receiver with T6J transmitter
- Battery pack Gens 1300mAh (7.4V) 2S1P 25C LiPo
- HI tec 311 Servos ( No load current 160mA)
Hi - try connecting the RX battery directly to the RX without using the ESC. There is no reason for what you are observing to happen under normal circumstances. Also, when the servos stop responding is the LED on the RX still lit, and if so, what color is it?
