Setting snap condition on 9 ZAWS
CA
Hi,
I would like to help my friend to set up a snap condition on his 9 ZAWS. However, I do not like to use the snap switch but instead would like to use the sticks for positive & negative snaps. I used to have a set but have since sold it over 10 years ago switching to the 14 & 18 MZ & didn't keep the manual.
I believe the Tx comes with a default condition that you have to transfer it to an empty condition slot, then set up a switch - kind of a safety switch - so you can then assign values & use the Tx sticks to snaps? Afterward you have to turn off the switch to deactivate the snap condition, is that correct?
Thank you.
Adrian
Thank you.
Adrian
