16/18sz Flaperon Programming
I have a Big Stick without Flaps and want to program Flaperon. On my 10C you would just select Flaperon and turn them on. I'm unable to find this on my 16/18sz radios. How do I set up the ailerons to act as flaps and ailerons(Flaperon)?
Don
Don
Flaperons are done in the camber menu. See page 136 of the manual.
https://futabausa.com/wp-content/upl...18/09/16SZ.pdf
I really appreciate your help with this.
Jorge
Look at page 136 of the 16SZ manual. Must be in 2AIL wing type. If you need to change that, note all your other settings since changing wing type wipes it all out.
Use a 3 position switch.
up=normal aileron
middle = take off flaps
down= landing flaps
Adjust rates in CAMBER menu as needed to get the deflection you want on the flaperons.
up=normal aileron
down= landing flaps
up=normal aileron
down= landing flaps
up=normal aileron
down= landing flaps
Wow, after spending several hours on trying to set this up on my 18sz i finally managed it. This thread helped me but i still had to set crazy rates on the Camber menu for ailerons. The main issue is there is no flaperon wing type, and the camber option assume that middle switch position is neutral and rate 1 is actually flaperon raises, and rate 2 is flaperon down.
so through a lot of trial and error i got it, even with mixes to elevator . But mix to elevator only works with rate 2, so i used the airbrake to create another mix to elevator up for flaps 1.
Phewwww
