GYA Gyro question.
GYA Gyro question.
Am I right in saying the GYA553 uses 3 channels for the gains at all times?
At the moment the 7114 Rx has all the channels used including one for the gain on a different brand gyro.
thanks
jason
thanks
jason
Correct. Each of the three channels are used for Aileron, Elevator and Rudder. Gyro, Gyro2, Gyro3, respectively. Gains are controlled for each Rate function and can be adjusted for each Gyro channel. The optional recover function would take up an additional channel if used.
Be sure to review the instruction manual as it shows the default channels related to each of the three gyro gains.
thanks
jason
Just so you know, the GYA553 gryo only needs a single S.BUS 2 connection from your receiver. Connections to Aileron, Elevator and Rudder are the typical analog or digital connections from the gyro.
thanks
jason
The GYA553 will require 3 additional channels if you choose to use all of them as well as a fourth if you want to use the recover function. Which transmitter do you plan to use with the GYA553?
I use a 7014 as well and have 2-flaps an on-board glow driver and using recover but not brakes.
Here is my channel/control layout;
1 Aileron J1
2 Elevator J2
3 Throttle J3
4 Rudder J4
5 Gyro SD
6 Aileron2 J1
7 Gyro2 SD
8 Gyro3 SD
9 Flap --
10 Recover SH
11 Flap2 --
12 Throttle2 SB - on-board glow
DG1 Gear RS
1 Aileron J1
2 Elevator J2
3 Throttle J3
4 Rudder J4
5 Gyro SD
6 Aileron2 J1
7 Gyro2 SD
8 Gyro3 SD
9 Flap --
10 Recover SH
11 Flap2 --
DG1 Gear RS
1 Aileron J1
2 Elevator J2
3 Throttle J3
4 Rudder J4
5 Gyro SD
6 Aileron2 J1
7 Gyro2 SD
8 Gyro3 SD
9 Flap --
10 Recover SH
11 Flap2 --
DG1 Gear RS
1 Aileron J1
2 Elevator J2
3 Throttle J3
4 Rudder J4
5 Gyro SD
6 Aileron2 J1
7 Gyro2 SD
8 Gyro3 SD
9 Flap --
10 Recover SH
11 Flap2 --
DG1 Gear RS
Ail
Ail
Ele
Ele
Rud
Flap
Flap
Nose wheel
Gear
Brakes (needs to be proportional)
throttle
Gyro
thats 12 so nothing spare. The GYA553 won’t work for me ☹️
thanks again
Jason
Jason, you are completely missing the point of S-Bus.
You have your general servo's into the receiver outputs. but you have 18 from the S-Bus output - the gyro function channels can be on 13, 14, 15 or 16.
I would re-map as follows .......
Direct connections into receiver
ch 1 - Throttle
ch 2 - Flap 1
ch 3 - Flap 2
ch 4 - Gear
ch 5 - Brakes
ch 6 - Nose Steering
Controlled from tx, but connected to 553.
ch 7 - Aileron 1
ch 8 - Aileron 2
ch 9 - Elevator 1
ch 10 -Elevator 2
ch 11 - Rudder
ch 12 - Gyro Aileron
ch 13 - Gyro Elevator
ch 14 - Gyro Rudder
ch 15 - Gyro recover
Depending on which transmitter you have, will dictate how you set up the 553.
The 32MZ and 16iZ can connect directly with the gyro and its very simple to move things around then.
Using the GPB-1 will also allow easy changes in all of the menu's.
If your just using the buttons on the case - you will be very limited in what you can change !
modtron
Oxford UK
ch 1 - Throttle
ch 2 - Flap 1
ch 3 - Flap 2
ch 4 - Gear
ch 5 - Brakes
ch 7 - Aileron 1
ch 8 - Aileron 2
ch 9 - Elevator 1
ch 10 -Elevator 2
ch 11 - Rudder
ch 14 - Gyro Rudder
modtron
Oxford UK
