Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
programming a 7 channel vs. an 8 channel
Old 01-17-2005 | 10:06 AM
stuffer's Avatar
Default programming a 7 channel vs. an 8 channel
I currently have my plane set up on an 8 channel reciever. using 2 servos for the rudder and elevator. how do I set up a 7 channel for the same operation? I can't seem to get the aux channel to switch over. I have the elevators plugged into 2 & 8. I have the ailerons in 1& 7.
Old 01-18-2005 | 03:57 PM
Default RE: programming a 7 channel vs. an 8 channel
Hi stuffer,
Please furnish us with a little more information such as, what radio you are using and what type of plane you are setting up.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Old 01-19-2005 | 11:32 AM
stuffer's Avatar
sorry, I am setting up a Lanier Staudacher 300 31.5%. I have a 9CAP.
Old 01-20-2005 | 09:54 AM
With an 8 channel receiver the easiest way is to use Aileron Diff for channels 1 and 7 and Ailevator for channels 2 and 8 with AIL 3 and AIL 4 set to 0%.
With a 7 channel receiver the easiest way I have found is to use Flaperon for channels 1 and 6 and then do Pmix from Elevator as Master to Aux 1 as Slave, with Trim on at +100% rates.
Sincerely,
Krysta
Old 02-09-2005 | 08:06 PM
MustangAce's Avatar
I have an Edge 540 with a 9C radio and the 7DF RX.
Dual elevator servos and dual aileron servos.
My goals are to have spoilerons and a switch to activate ailevator function if possible.
Your help is greatly appreciated
I have read the FAQ but to no avail []
