7C and crow?
FL
7C and crow?
Hello.
I have a 7C radio and used on it on my ultra stick 60. I have everything set up and crow works but there are a couple things I can't get to work.
First here is my set up as it is now:
Channel 1 = left aileron
Channel 6 = right aileron
Channel 5 = right flap
Channel 7 = left flap
When I went to first program everything, I went to the Faq page and followed the instructions ( I think). Anyway, crow works and just flaps work but when I go to program elev to flaps, instead of flaps the ailerons work. Otherwise, I give it up elevator and the ailerons go down instead of flaps. What did I do wrong?
Thanks for any help
Mike
Thanks for any help
Mike
RE: 7C and crow?
Hi Mike,
You didn't do anything wrong, with the Elevator to Flap mixing, it will make your ailerons acts in unison "as flaps".
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
FL
RE: 7C and crow?
Thanks Krysta,
So I can't make the flaps work instead of ailerons?. I have used this mix on some other planes and loved it but it was always the flaps working in unison with elevator, not ailerons.
Thanks for any help
Mike
Thanks for any help
Mike
