Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
7c setup question
Old 05-22-2005 | 09:28 PM
My Feedback: (10)
Default 7c setup question
hello I have a 7c radio and a ultra stick I have setup on. I have used the futaba site and set it up for the quad flap wing like the site said. I have a mix to use one switch and I have channel seven asigned to another. I have ran into a problem where I cannont adjust the channel seven flaps down travel. Is this a limitation of the radio or am I missing something? thanks
Old 06-09-2005 | 08:35 AM
Default RE: 7c setup question
I think that I have the same problem. It would be nice to hear something on this from Futaba.
Old 06-09-2005 | 09:51 AM
Hi rccrazedman,
If you are trying to adjust the endpoint of channel 7 you will need to go into your Endpoint screen, select channel 7, and when you move the switch that you have assigned to your down flaps, you will see this toggle to the down travel side.
We originally suggested that you set this at 0 percent, but as with all of our mixing FAQ's, all set ups are different and you may need to make minor adjustments through all of them per your planes requirements.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
ORIGINAL: rccrazedman
