Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Programming Help - 9C
Old 08-31-2005 | 06:25 PM
My Feedback: (17)
Default Programming Help - 9C
I'm trying to set up a switch to provide an up elevator offset to better trim a plane for landing. The plane is set up with dual elevator servos using channels 2 and 5, with a program mix with ch 2 as the master and ch 5 as the slave. The trim offset is set up as a program mix using offset as the master and channel 2 as the slave. When the switch is turned on for the trim offset, only the elevator on channel 2 responds. Both link and trim are turned on for the elevator ch 2/ch 5 program mix. Why won't channel 5 follow what channel 2 is doing?
Chuck
Old 09-01-2005 | 11:45 AM
Default RE: Programming Help - 9C
An Offset mix will not give you a Link Function which is what you would need to make both of the servos react to this mix. You simply need to do a second mix with master as Offset and this time Gear as the slave, set it to the same switch and the same percentage.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
ORIGINAL: chuck l
Chuck
