replace rx wire
RE: replace rx wire
Hi TZona,
At this time our turn around time is approximately 7 business days due to an extremely busy time of the year.
As for pricing, the labor will be around $15.00 and the antenna would be $.80.
If you are very good with a soldering iron, and for safety considerations do a COMPLETE and thorough ground check, and the warranty is not an issue, you would want to look for 24 gauge wire, and the length will be:
approximately 19 1/2" for surface
approximately 39 1/2" for Air
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: TZona
how much is this, about how long does it take?
thanks
thanks
