6EXAP Flaperon
FL
6EXAP Flaperon
When I program the flaperons, can I set the flap dial all the way to the right for "Raised" and all the way to the left for "Lowered" instead of worring about stopping the dial at a certain place to get it back to center?? Thank You.
P Scott Carlson
P Scott Carlson
RE: 6EXAP Flaperon
Hi scooter052566,
Unfortunately, no, the 6EXAP does not have this type of capability.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta
ORIGINAL: scooter052566
P Scott Carlson
P Scott Carlson
RE: 6EXAP Flaperon
I was able to do this. I set the flap trim to 0 and adjusted the servo horns so when the dial was all the way counterclockwise, the ailerons (flaps) are level, then I turned the dial all the way CCW and increased the aileron (flap) trim till I got the down throw I wanted. Then I set the throws for channel 1 and 6 for the ailerons. It works just fine. I even have aileron differential dialed in to remove adverse yaw.
