Help with 9C Trainer function & helicopters
My Feedback: (16)
NJ
I have used the Trainer function MANY times with my 9C with no problem until I tried it with my helicopter. When I pass control over to the student all channels work fine except for the throttle. The throttle does not respond to the student's command, it is dead. I tried everything, even reading the manual twice , but finally gave up.
We are using two 9C super transmitters.
Can the Trainer function be used with helicopters?
George
George
RE: Help with 9C Trainer function & helicopters
You may need to check to make sure all of the channels in the master transmitter are set to "FUNC". This lets the slave transmitter use the master transmitter's mixers. Otherwise, the slave transmitter must have all channels set identically to the master.
