6exh cannot on
6exh cannot on
Hi...i've got this major problem last few days during funfly...after plug-in the trainer cord from my friend's futaba 9chps, my tx cannot power on...then i'd un-plug the cord and tried to power on my 6exh, the TX still cannot on....Suprisingly, when my friend use his TX with others, there is no problem...my tx battery read 10.4V...Does this mean my TX got a problem with the electronic part inside?
RE: 6exh cannot on
Hi faizal7678,
If I am understanding correctly, your 6EXH worked correctly until it was plugged into your friends 9C by the trainer cord? Is this correct. If so, did you use the correct trainer cord, and were both TX's powered off or on.
We would need a little more information to be able to give you some direction on this problem.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: faizal7678
RE: 6exh cannot on
okay...firstly, my tx worked well before plug-in the trainer cord...Both tx is power off during the cord pluging. We are using the trainer cord provided by futaba.
the problem is when i'd tried to power-on my tx which is 6exh, the tx cannot on. turn off the power for both tx, un-plug the cord, tried to power on my tx and its cannot on. Hope this info is helpful. Thanks.
