Split elevators
Split elevators
I have a plane with split elevators. They are plugged in to channels 2 & 6. I am using a Futaba TX6A tx. The elevator function which is set up on the PMX 1 with 2 as master and 6 as slave work fine. My problem is when using elevator trim , only the side plugged in to ch. 2 responds. Where did I go wrong? Hope you can help. Tks.
