Crow and saving Trims
CA
Krysta or Bax
On the 9 ZAW I want to flip a switch so it goes into crow mode and then flip another one and get full aileron mode, but have the trim settings saved for each mode so that way when it goes into crow it wont go out of trim. What switches, channels etc. should be used and conditions if any needed. The airplane is a ultra stick.
Dan
Is that a bit wordy or what. ha ha
Dan
The trims are set by model. In each model, you can adjust which trim operates which channel, and the amount of control surface movement per 'beep' of trim, but you cannot set them so that they have different values in different conditions.
For the setup of a complex aerobatic aircraft, please see this FAQ:
http://www.futaba-rc.com/faq/faq-9z-q205.html
