Super 7UAP Question!!
Hi I have the Futaba Super 7, and have a question that is not addressed in the manual: how do you use the RESET function to reset the TX memory for a new model setup? I can get to the screen in the PARA sub-menu, but can't figure out how to actually reset all the parameters to setup a new model. Any help is greatly appreciated!!
RE: Super 7UAP Question!!
When you get to the PARA menu, you will see an arrow flashing under the model that you are currently in, at this time you will simply need to press the + and - keys together at the same time, you will hear a beep and this lets you know that your model has been reset.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: FalconDoc
