8UAF Mixes for Sport Plane 4-Servo Wing
NJ
Futaba,
Thanks for your help with this.
My radio system is an 8UAF with an R-148DF Rx. I want to lower the flaps using the retract (GEA) switch E - without using a Y-cable.
I have a sport plane with the following wing setup:
Ch1 = Left Aileron, Ch7 = Left Flap, Ch8 = Right Flap, Ch6 = Right Aileron
One of the mixer setups I tried was:
PMIX-1 Ch7 > Ch8, 100%
PMIX-2 GEA > Ch7, 100%, Link ON
FLPRON to merge the two aileron servos on channels 1 and 6
PMIX-3, 4, and 5 - I used three more PMIXs to deactivate knobs 6, 7, and 8.
The problem is that the flap servos do not travel the full range of motion; they move about half of what they are supposed to.
I also tried to mix OFS to Ch 7 with similar results.
Please advise is there is anything else to try with this.
Paul
Paul
RE: 8UAF Mixes for Sport Plane 4-Servo Wing
Hi Paul,
You may want to try doing the Flaperon, then doing one Pmix with Offset as Master, Channel 7 as slave, at 100% on your gear switch, then do the second on the same but with Channel 8 as the slave. Do a third mix from Gear to Gear at Negative 100% to cancel out the channel 5 servo movement, and then your other mixes to cancel out the dials.
This might work better for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
Sincerely,
Krysta Hunt
ORIGINAL: flyingw
Futaba,
Paul
Futaba,
Paul
NJ
Thanks Krysta,
I will try that later. Since channel 5 is unused (I was to plug the receiver battery in there), do I need to use up a mixer to cancel the Ch5 movement?
In the meantime, can I use a slight variant:
OFS > Ch7 50% on Switch C (center)
OFS > Ch8 100% on Switch C (down)
to get 1/2 and full deflection?
Thanks again,
Paul
Thanks again,
Paul
NJ
Krysta,
I tried exactly as you instructed, and the flaps servos in channels 7 and 8 still provide about 1/2 of the expected movement - the servos in the other channels have more throw.
Is there something about the offset capability that limits the overall throw?
I duplicated the arrangement using the center and down position on switch C successfully, but had the same symptom - less than full throw on channels 7 and 8.
Please advise. Thanks,
Paul
Paul
NJ
I am advised by Futaba telephone support that you only get travel from the middle point to one endpoint when using an offset mixer - that explains the 1/2 throw on my flaps.
It is possible that the only way to get full throw is to use a dial.
