9C Throttle Hold Problem
NC
When I switch my throttle hold on the motor(electric heli) goes to full throttle(this was the cause of my last crash). I read past posts on this subject and everyone said then your throttle channel needs to be reversed, mine is not reversed but works correctly. When I do reverse it then at low stick the motor goes to full throttle...I have used everything from zero to -50% on the throttle hold settings....I even tried +50..can anyone help me with this?
thanks
-Bill
thanks
-Bill
According to the manual, you first set up the throttle so that it operates in the proper directions, and you make sure the idle and top-end endpoints are as you desire. Then, move the throttle stick to the idle position. You then go into the throttle hold function, turn it on, and then adjust the position. The manual states that the Throttle Hold function has a range of -50% to +50%, centered about the throttle idle position.
