Snap Roll question
My Feedback: (13)
NC
Snap Roll question
Bax,
I have a new 7c 2.4 radio system. It is in a Showtime 90. I have the ailerons programed as flaperons and the elevator servos slaved together. Channel 5 is slaved to channel 2. When I hit the snap roll switch the elevator half on channel 2 will move up, but the elevator half on channel 5 does not move at all. When I pull back or push forward however on the elevator stick both sides respond as they are supposed too. Is this normal, or do I have something programed wrong possibly. This is my first futaba radio system so I will need as much guidance as possible I am sure.
Alan
Alan
RE: Snap Roll question
Snap Roll Switch? Man, am I behind times! Is there a switch for a Stall Turn, a Loop, or a Barrel Roll? I don't want to put anyone down here, but the Snap Roll has been around for some time, and is not too complicated to learn to "do it yourself." If you have to have the switch, make sure it can't be accidently triggered or it could mess up your airplane at the wrong time and place, like while in a Landing Approach and just beginning your Turn to Final. A Snap there will mess up your day for sure. I can't help it, it just struck me funny, a Snap Roll Switch! What next?
My Feedback: (61)
I haven't found out how to fix this either. It seems that the 7C does not link mixes. Meaning that if you use the Ailevator function to set up elevators on different servos, when you do a rudder to ele mix only the ch 2 elevator moves, not the ch 5 elevator. I haven't found a remidy to this problem other than mixing both ch 2 and 5.
