Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
10c question
Old 04-14-2009 | 07:57 PM
Default 10c question
I have a 10c with R617FS receiver that I want to use on a heli with 4 servo ccpm. Is it posible to change the function from ch 8 to ch 7 so this receiver can be used.
Old 04-15-2009 | 09:29 AM
Default RE: 10c question
Yes. I can't remember if you have to go to the "Parameters" menu or the "Model" menu, but you can see that there is a thing that says (somehow, I'm not sure what the abbreviation is) 10 channels. Select it with the joystick, and then use the scroll wheel to change it to 7ch mode.
Old 04-15-2009 | 11:49 AM
Bax
In the 10C, you will change the output type of the transmitter in the Parameter section of the Basic Menu. Change to 7-channel mode.
