Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
esc plug in on reciever
Old 06-24-2010 | 11:59 AM
Default esc plug in on reciever
Iam trying to set up my 7c 2.4 to fly electric. When I hook everything up and plug in the battery/esc into the battery slot everything responds correctly except for my throttle. Is there something that I am missing? I have the 7 channel long range reciever that came with the radio when I purchased it.
Old 06-24-2010 | 12:09 PM
Default RE: esc plug in on reciever
<deleted, factory support forum only>
Old 06-24-2010 | 12:11 PM
I tried that but when I did the esc wouldn't "arm" the motor.  When I put it into the battery/7 spot it arms the motor but does't respond to any throttle movements.
Old 06-24-2010 | 12:19 PM
Old 06-24-2010 | 01:37 PM
Futaba's Throttle is reversed from what other brands would be.
Try going into the Reverse menu, change your throttle only and then completely reset your ESC.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 06-24-2010 | 02:30 PM
Thank you for the help. It's greatly appreciated.  I never even thought about the servo reversing being an issue.  Gotta think outside the box sometimes.
Old 06-24-2010 | 10:14 PM
hugger-4641's Avatar
not sure what rx you are using, but on all my electrics, the Esc does not plug into the battery plug, it plugs into channel 3, which is the throttle channel.
