7c 2.4 ELEVATOR TO FLAP MIX
how do I set it up so when I input elevator, the ailerons act as flaps in a mix? I want a few degrees of flaps (ailerons both acting as flaps) when I input up or down elevator. I have tried to put 1 aileron in channel 6 and that didn't work. suprisingly enough, the one in channel 1 only worked one way like a flap. is there multiple mixes I need to activate?
First off, you'll need to activate the Flaperon Mixer to get the ailerons to act as flaps, and then activate the Flap Trim to adjust how much flap action the ailerons will have when you adjust the flap control.
To get the flaps to move when you move the elevators, you'll need to use two mixes. One mix will be Elevator -> Flap and the other will be Elevator->Aileron. Adjust the direction and percentage of mix to get them to move as desired. When you move the elevators one way, the ailerons will both deflect up; and when you move the elevators the other way, the ailerons will deflect down.
