Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Engine recommendation for this model. >
Old 10-20-2010 | 08:55 PM
Broken Wings's Avatar
My Feedback: (20)
Default Engine recommendation for this model.
I found this on sale and since it says "or equivalent power gasoline engine" what brand/size 2-stroke gas engine would you use if it was your model?
Thanks...
ID:	1520269   Click image for larger version
ID:	1520270   Click image for larger version
Old 10-20-2010 | 09:04 PM
My Feedback: (12)
Default RE: Engine recommendation for this model.
DLE20 should be enough for this( it looks like it's a sport plane) a DLE30 may be a bit much. There are plenty of 26cc motors out there SPE, CRRC, Evo and so on...
Old 10-20-2010 | 10:11 PM
My Feedback: (20)
There have been a few built using the OS 160 twin which weighs about the same amount as the 30cc DLE.
A later model called the Dragon Lady came out after this one.
The model is kind of old so it's beefy, foam wing, a good bit of ply. I'll probably cover it in some sort of iron on fabric.
The instructions recommend the 108 glow...
Old 10-23-2010 | 12:26 AM
I had the Dragon Lady (same thing) with a ASP108. It flew great for a sport plane but most of my landings were dead stick because of the crap motor.ha
Ron
Old 10-23-2010 | 01:39 AM
My Feedback: (118)
I would not try a gasser on this plane as it will weigh too much. 880 square inches is not much wing. I would use a Saito 1.20
My 2c
Bliksem
