What Aircraft are you installing your DLE20
#1604
Thats right.We wont know till someone tries it.=)
What the hp range of the 20cc?
Sig list the upper wattage @1700 which is about 2.3 hp. Is it fair to compare this way??
I understand that vibration may be an issuse depending how well built the model is.
#1605
If you did have a hp range from the manf., it's generally about useless, somebody's dream numbers or numbers obtained under conditions impossible to duplicate in actual conditions. Much better to compare commonly used prop combinations. They'll give you a solid comparison.
And yes, vibration will certainly be an issue....
#1607
From what i remember seeing of the T-clips 70, a DLE20 wont fit in the cowl. This would be the equivalent of sticking the DLE20 in my 1/5th SIG Cub. Would be too nose heavy, and would shake the crap out of it. I joked about sticking a Magnum 91 FS on it, and they said, that would be different, let us know how it goes, in the way that, should I actually do that and it tears the wings off, well, good luck with that. I think a OS 70 would be plenty of power for this plane though, I have seen the 70 on the Great Planes Fabric cub, and it moved really good.
#1608
If it fits in the cowl was my other concern as well.
As far as being nose heavy it's possible to shuffle equipment around and move servos to the rear.
Only time will tell.
Nough from me here.
Nough from me here.
#1609
My thoughts are the T Clip is gonna be to lightly built for a DLE 20, as an alternative, the OS 15 cc gas job might work. I think the best thing to do is pick up a Saito .72 for her, break it in, TUNE it in, then fly the gut's out of it.
#1610
Thats what I was thinking, that or the gas .82 version.
#1611
Looks like a new possible candidate for the DLE 20cc.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEKBF&P=0
#1614
LA
A friend of mine has a DLE 20RA in this
http://www.horizonhobby.com/products...arf-HAN4215#t1
According to the specs it's 2 pounds lighter than the Phoenix version. This plane flies awesome with this combo. He has added a lot of weight to it as well by adding custom wing-tip smoke.
https://www.youtube.com/watch?v=eEd3lwoNbHM
#1615
#1618
CA
A 20cc gasser 2 stroke is equal to a 1.20 four stroke glow. Something like a YS 1.20 or a 115FZ. I have flown both the DLE 20c and the YS 110FZ in the same plane and the power is about the same. I think the 1.20 2 stroke glow would be more powerfull than the DLE 20 but not by much. There's also a weight difference the DLE is heavier than a 1.20 2 stroke. The Phoenix Model Sbach might not go vertical.
#1619
Just so you know I run a DEL20 in a 4*120 and I damn near lost sight of it on an 80* climb out. Wasn't a pure vertical, but close, it became a spec in the sky. On a pure vertical it will roll up pretty high before it falls out. My only problem is I cant get it to slow down enough to land.
#1620
CA
You can do the same thing with the YS 110 FZ but you can't hover close to the ground with a 120 size plane. Now a 26cc engine would get you hovering and there not much more in price.
I had a CRRC pro 26cc in a Hanger 9 90 Funtana that would dance nicely. A DLE 30 would be great in a 1.20 size 3D plane if you like DLE for $50 more.
I have a DLE 20 I am putting it in a 60 size plane
#1622
LA
You don't want the Phoenix plane from Tower Hobbies........................................... .........Unless you are aerobastic! LMAO
NOTES FROM OUR TECH DEPARTMENT[TABLE="align: center"]
[TR]
[TD]This is the Radio Controlled, 1.20 Glow or Electric Powered 1/4 scale
Almost Ready to Fly Sbach 342 Scale Aerobatic Monoplane from Phoenix Model.
Recommended for intermediate level aerobastic fliers.[/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[/TABLE]
#1623
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[/TABLE]
#1625
I have Flaperons on it, when the engine idles down it lands nice, problem yesterday was I couldnt get that damn engine to idle down. When I dropped flap the plane scooted sideways and became a handful. I finally just killed the engine on final and was able to land it.
