getting my first gas engine
Old 04-07-2011 | 12:28 PM
Default getting my first gas engine
here very soon i'm getting my first gasser engine i'm going to get the RCSSV26 and i'm going to be running with a 3 blade 16x8 prop and im haveing a problem finding a spinner and adapter for it i'm looking for a 2 1/2 or a 2 1/4 spinner dia. can anybody point me in the right dircetion
Old 04-07-2011 | 12:41 PM
Whistling Death's Avatar
Default RE: getting my first gas engine
Tower has lots of them.
Old 04-07-2011 | 01:09 PM
w8ye's Avatar
My Feedback: (16)
I would venture to say that the 2 1/2" would be the minimum for that engine and prop
Old 04-08-2011 | 03:38 AM
Zippi's Avatar
My Feedback: (10)
ORIGINAL: armyguy466
here very soon i'm getting my first gasser engine i'm going to get the RCS SV26 and i'm going to be running with a 3 blade 16x8 prop and im haveing a problem finding a spinner and adapter for it i'm looking for a 2 1/2 or a 2 1/4 spinner dia. can anybody point me in the right dircetion
armyguy466,
The 16X8, 17X6, and 18X6 props are used with most 26cc-30cc gassers running a two blade prop. I could be wrong but you may want to try a 15" dia. prop for the 3 blade. Let some guys chime in here that are running a three blade prop. They will know for sure.
Old 04-08-2011 | 04:48 AM
MetallicaJunkie's Avatar
i agree zippi //////////try a 15x6 x3
Old 04-08-2011 | 06:06 AM
thanks i ment to type a 15 for the 3 blade just had a brain fart when i was typing it
Old 04-08-2011 | 07:40 AM
Don't feel too bad as that happens to the best of us at times
Karol
Old 04-08-2011 | 09:08 AM
has anybody used the rcs sv26 from troy built models i'm going to put in my cessna skylane my whole problem is finding a spinner and adapter for the spinner for the plane every 2 1/2 spinner i find needs to be modifed
Old 04-08-2011 | 10:06 AM
scooterinvegas's Avatar
I think Dave Brown will custom cut a spinner for $5-$10 for any prop. Call them and ask.
Old 04-08-2011 | 11:03 AM
i forgot about dave brown spinners i'll have to give them a call
Old 04-08-2011 | 11:00 PM
ORIGINAL: scooterinvegas
for the price dave brown make a just as good of a spinner as tru turn, its just that dave brown spinners tend to be a little thinner(lighter).. and that's not a bad thing if you dont over tighten them
Old 04-09-2011 | 07:18 PM
whats the best way to set up my gas motor i plan on useing a servo for the choke i'm use to nitros and this is my first gasser i know the fuel lines setup is differnet i don't plan on smoke or any flying tricks just a good old fashion scale flying plane how should the vent be and i will be useing a fuel dot
Old 04-09-2011 | 07:32 PM
w8ye's Avatar
My Feedback: (16)
Read the newbie "Sticky" at the top of the page.
Gas throttles are typically very sensitive down close to idle
