Small 3 Pin Deans Connector
RE: Small 3 Pin Deans Connector
if finding a spare connector is whats keeping you from using your engine... you could always convert it to a standard 3 wire connector.... i did that with some old futaba g servos many years ago to use on a ore modern receiver(similar situation)
found this http://www.google.com/search?btnG=1&...ns+micro+3+pin amain hobbies
My Feedback: (19)
ORIGINAL: DAN REISS
Who carries the small three pin Deans connectors that are used with the Brison sensor line and CH ignitions? It's the one with the notch in it. I'll try to upload an image. Thanks, Dan.
My Feedback: (16)
Tower has them. I just bought some about 3 months ago. They have the small two and three sets as well as the large stuff.
In the picture, they show the four pin along with the three but the title says three pin and that's what I got.
http://www3.towerhobbies.com/cgi-bin...?&I=LXKX41&P=7
Any of the well stocked electrical outlets carries them. They have been a standard connector in electronics for a very long time. A quick example that comes to mind if Fry's Electronics. Bear in mind that connector type is not a requirement. You can just as easily use a standard 3 pin radio connector to accomplish the same task. Just replace the one that you're trying to mate the other to.
