HELP Please!!!!!
Old 06-16-2011 | 12:55 PM
prebres's Avatar
My Feedback: (7)
Default HELP Please!!!!!
Please help guys. I have a 35cc Maccullogh engine converted for RC use. I can't get it to run. It doesn't seem to pump gas. Please look at the pic of the carb and tell me which fitting I need to attach the gas the gas line to. #1 or #2 I am pulling my hair out.
walbro by prebres, on Flickr
Old 06-16-2011 | 01:00 PM
My Feedback: (19)
Default RE: HELP Please!!!!!
Gas to #1, cap off #2. Not sure but I'm guessing #2 was for a primer. Make sure the diaphram under the cover near #1 is flexible and that the pump flappers are not curled or otherwise distorted. Also, be sure the diaphram under the cover with the 4 retaining screws is also flexible and that the metering needle also moves freely. You might need a rebuild kit if the carb has very much use on it.
Old 06-16-2011 | 01:25 PM
prebres's Avatar
My Feedback: (7)
Thank you Truckracer.
Old 06-16-2011 | 02:45 PM
Yours is a Wt Series carb. Here is the maint manual for it. http://wem.walbro.com/distributors/s...s/WTseries.pdf
Don
Old 06-17-2011 | 04:08 AM
prebres's Avatar
My Feedback: (7)
Awesome, thanks Campgems.
