Using servos with nylon output shafts in a gasser
When using nylon output shaft servos in a small gas engined model, is it necessary to take any additional precations to guard against the servo arm retaining screw from vibrating loose from the output shaft, or is the friction between the metal screw and the nylon shaft sufficient to keep it tight ?
Karol
Karol
RE: Using servos with nylon output shafts in a gasser
I have 5 spektrum servos on the elevator, throttle and ailerons of my 26cc Yak. No trouble in 4 years.
On the 50cc I tend to put a dob of thick superglue next to the edge the head of any nylon servos (throttle) after it's screwed in just in case.
You know not to use Loctite on plastic gears, so I shan't remind you!
ORIGINAL: dogshome
Karol
I have a Giant Stik that has flown with everything from a 42cc single that was quite a shaker, to the 50cc twin I presently have on it. It has been flying for years with Futaba 3010 servos with no problems. (Plastic gears and output shaft, no thread glues.)
My gas 72" Katana, 72" Giles, big 76" Tiger Moth biplane, and others all have the same basic setup with no problems and many aggressive flights. Note however that I don't fly 3D, and would probably need stronger servos if I did.
AV8TOR
AV8TOR
ORIGINAL: av8tor1977
AV8TOR
AV8TOR
I really like the Giles, but the Katana does fly a bit nicer. The Giles will snap on you a lot easier than the Katana. I can drag the Katana in for really slow, slow landings without worrying about it snapping on me. The Giles will snap if I pull too much elevator coming out of a loop or dive. Both of them have reasonable c.g.'s and elevator throws set up so that shouldn't be causing it, but the wing loading is a bit higher on the Giles.
AV8TOR
AV8TOR
this past saturday had a cheapo hitec 311 fail as a choke servo on my 3w80cc... i didnt strip it just died........ i did an emergency repair, luckily my buddy brought his cordless drill with him... i drilled a hole in the FW to use the old manual push rod method with a 4-40 all thread rod and a ball link.... it worked like a charm
IL
ORIGINAL: Tired Old Man
No extra precautions needed with the screws used in nylon output shaftes. The problem children are the metal output shafts using machine thread screws. A lockwasher is not enough.
