DLE plug cap/plug mod...yes/no?
as a newbie i look into all ways to solve any issue before it is an issue.
the postings on this board have convinced me that pushing the plug cap onto the plug for this maker is a rather tough one.
so i ask, would filing a slight round on the corners of the plug help with the installation/removal of the plug cap?
My Feedback: (19)
ORIGINAL: summerwind
Of course you can modify the cap as suggested by others, Capt'n John has often suggested a common mod using a small screw type hose clamp to retain the cap while making it easier to install and remove .... and it still remains reliable. This is truly one of those things where it is all just a matter of personal preference.
i think the plug capis fine on RCxcell ignitions it just take some elbow grease to put on, and a pull and a twist to get it off.... the tighter it is the better[8D] you dont want it all loose and sloppy now do ya?
you guys are right.............i'm just now getting the DR1 finished and gettin close to hookin things up and thought i'd ask.
i've read so much here and learned more about gas engines than any books written on the subject that i am down to the fine lines of things.
i'll leave things as they are.............
