U.S. - 41 / ( Quardra ) Choke ?
NM
I have a brand new out of the box U.S. - 41 that I tried to start up for the first time. It's on magnito, and has a spring starter. I checked the needle factory settings first, and found that they were about 2 turns each, out from the bottom. I left them there at those factory settings. I then placed my thumb over the Carb, and rocked the Prop back and forth on compression 6 times, my thumb was only moderately wet with gas, but I decided to try it. Crank, crank, crank using the spring starter for about 5 minutes, and no start !
I decided that it might be flooded, and gave it a rest. I came back about 30 minutes later, and she started right up. I then leaned out both needles accordingly, and she now purrs like a kitten. It is obvious that I flooded it on my first attempt to start it. So, my big question is, what's the correct chokeing procedure to prevent flooding it again ?
Thanks for your help Gents.
Ed
Ed
RE: U.S. - 41 / ( Quardra ) Choke ?
I don't think there's a universal answer to your question. A lot of what it's going to take will have to do with whether you've refueled since starting last. Pulling fuel through an empty line will take more than when the line's full?
With a little use you'll get a feel for what it's going to take. That's a great engine well known for it's reliability.
